08-07-2005, 09:02 PM
Ca
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
Thanks!.... Surprisingly enough I could easily fit 12" rims under the back. I merely had to tie back the emergency brake cables a little closer to the frame, but that was about it...
Yes... The PS is great...especially if I can find that valve that was mentioned here once.
Scott is a very agreeable guy. I'm sure you'll be happy with the wheels. He has a new model out and they're drop dead beautiful.... You'll love em!
