Old 08-07-2005, 09:52 PM
fxbill's Avatar
fxbill fxbill is offline
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
Found it!.... It's Heidt's adjustable power steering control valve. It's not just a simple needle valve that I originally thought. It is actually a spring loaded plunger valve that bleeds off pressure above the set point and returns it to the return line. That way regardless of the engine speed the feel will be the same instead of varying like a needle valve would do.
The url for it is... http://www.heidts.com/heip27.htm#power
$79....not bad!
