Thanks guys. Yes Elliot helped. The engine needs an enclosed breather system, so we need to change the valve covers so that both of the valve covers had breathers. One goes to the PCV valve and back to block and the other goes to the air cleaner. I needed to get an air cleaner with a nipple, but I had no problem finding one. I blocked off the block breather. As far as adjustments, I just cleaned the carburetor, changed the plugs and then we adjusted the carburetor to run leaner. We ended up at a better setting then before so I will not make any after test changes. There is a date code on the block.
As far as testing, the BAR does not have any requirements for pre 66-67. Since I was older, the BAR tested used the minimum requirements from 66-67. After 67 the requirements get tighter.
I'm not sure what the bond is, but it is required. I have to have the bond because the registration was pulled. If you are just registering, I'm not sure if it would be required.
Dave V
