Old 08-09-2005, 06:07 PM
CJ428CJ's Avatar
CJ428CJ CJ428CJ is offline
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
Neutral
Default Headlight Low Beam Problem
Bob,
My low beam headlights have started acting up. They essentially cycle on and off. About 1 minute on followed by 1 minute off (although it sometimes is as short as 15 seconds or as long as 3 minutes). The highbeams and parking lights all work fine. The problem is very consistent and it doesn't matter whether the car is running or off. Since the problem is so consistent and doesn't seem to be the result of a vibration, I assume it's not a bad connection. Seems like it's likely a bad dimmer relay. Does that sound like the likely culprit to you or is there something that I might be overlooking?
Chris
