Old 08-11-2005, 12:38 PM
Dwell readings on some distruibutors can be tough to get right, use a little common sense when setting it. A combination of dwell and a reality check of minimum point gap.
For instance if the dwell reading is 22-24 but the point gap is really small (.010 as an example) that just aint right! The point gap needs to be a minimum of .015-16 regardless of dwell reading. There are several things that can result in an inaccurate dwell reading.
