Old 08-11-2005, 12:52 PM
Ford of France Ford of France is offline
Cobra Make, Engine: CSX 2189
Typically, each set of points is set individually. This is accomplished by blocking open one set of points while setting the other. In your case, a 26-28 degree dwell setting on each set of points should give you around 30 total dwell. The overlap is around 5 degrees once both set of points are set. Use a dwell meter and don't depend on a feeler gauge, if at all possible.
