Old 08-11-2005, 02:44 PM
JayBar's Avatar
JayBar JayBar is offline
Cobra Make, Engine: BDR#078,408 Dart Block, TKO 600,Indigo Blue, White Stripe
Send a message via Yahoo to JayBar
jeffko
Originally posted by jeffko
[Long term solution: ??? We should all do some research and post to this thread until a viable solution is found.
[/b]
Why do you insist on re-inventing the wheel. I gave you a viable solution. It's not rocket science. You can buy the Wilwood master and a rebuilt slave from Napa. Insulate the master and line to the slave. That will cure any problem you have. One step fruther would be to wrap the headers. Now if you like to spend money and fabricate things, you could buy the Wilwood slave, but it is a "puller" and will need a custom bracket.
AS far as the Mcleoud unit I have heard nothing but horror stories about it. Image a leak inside your bell housing, you would wish you had a slave cylinder from a Yugo instead.
JayB
Jupiter, FL
