Thread: Engine Oils!
Old 08-14-2005, 08:08 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Default Re: Engine Oils!
Originally posted by scootter
In talking with an engine builder, I was told that almost all oil makers have remove Zinc ( I think) from their engine oil which is causing premature wear and failure on cams and lifters. He is saying to put a can of STP oil treament in at every oil change. I did post the on another site and they recommend using oil that is about $40 per gallon. I think I would rather buy a can of STP if that works.
I don't believe STP has the Zinc additive, as I think it is only a viscosity enhancer, i.e. thick petroleum.
You can buy a zinc additive from GM parts that will replace/restore the zinc that is critically needed for parts that do alot of rubbing. I'd probably use that, and not STP or cam break in lube.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
