The problem has been fixed. I replaced the stock fans with 10" fans from Spal.
The part number is 2057. They pull 1070 cfm each.
Installation is pretty straight forward. You will need to remove the shroud from the car. Remove the stock fans. Line up the new fans and drill new holes. I used 5/16"x1" stainless bolts with lock nuts to attach the new fans.
You can swap the plastic part of the plug onto the new fan and they will plug right in. The metal pins will slide out of the Spal plug and into the BDR plug.
Jim Pomroy
Have Fun!
BDR #930
08 Corvette Coupe
92 Sunburst Yellow Miata
#81 Saturn V Miata Crapcan racer
Panoz GTRA #42
