08-14-2005, 04:18 PM
Ca
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
Try an early Mustang ll power steering unit. 3.5 turns lock to lock and with a Heidt's adjustable relief valve on it you can dial the steering force to exactly what you want. I just finished installing this on mine and what a difference!!!!!!! Took most of one day to do the complete job. Email if you need specs or photos...
fxbill@comcast.net
