Old 08-15-2005, 04:37 AM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
First, make sure the OD of the center between the inner and outer flanges matches or is slightly smaller than the hole. Warm the grommets by laying then in the sun, with a heat gun or sit on them, lubricate them with WD-40 or soapy water, then work each grommet into a hole. Pinch the grommet together, get one flange in, then push the rest in until it snaps into place.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
