  #324 (permalink)
Old 08-15-2005, 03:17 PM
sky-chicken's Avatar
sky-chicken sky-chicken is offline
Cobra Make, Engine: JAC 427
Welcome ! So far I kept this info from this post :
(MilwDoug )
Has an 8.8" Ford rear end..
Rear brakes are probably 94 Mustangs.
Front brakes are 79 Granada.
Catalytic Converters are 94 Mustang but are custom cut.
It has a reinforced windshield for rollover.
Rear springs come from Dales race shop. 175 # rating.
Front are Carrera coil over springs and shocks.
Steering column is a Chevy S-10 pickup
Steering rack is from a 79 Mustang 2.
Finish Line has all sorts of after market parts and will probably have the Lucas taillight assemblies.
The entire interior was made at Excalibur.
The radiator is special. Was made at Scotty's Radiator Shop in Milwaukee.
The temp gauge runs about 20 deg high. The engine normally runs at about 190 degrees.
Goodyear on Hwy. 100 and National can do front end alignment.
A 1 drive shaft built the driveshaft.
The compressor on the air conditioner is stock but all the lines are custom.
The brake master cylinder came from NAPA but no one knows who made it.
The top hose is a 94 Mustang hose cut to fit.
The lower hose is a universal radiator hose.
The alarm cuts out the fuel pump, the starter and the ignition. It cannot be bypassed. You can not get duplicate keys. There was a red master key that can be used to reprogram the gray keys if you have the instructions. Made by Hella.
(Aloys)
The front brakes of my `95 Excalibur are from the `82 8Cyl. Mustang
(Excaliber)
Polished front calipers replaced with Dynalite Wilwood calipers. exact match!
understand this is the gentleman who now owns the Excalibur molds:
Bill Begella
7381 California Ave.
Youngstown, OH 44512
1-330-726-1880
