I have 8' of -10 oil line, dual one quart filters and a cooler under the radiator. Total capacity about 3 quarts. I run a blueprinted Melling high volume pump and get 85 psi cold at speed, 75 hot. 50-55 cold at idle 40-45 hot.
A high pressure pump will get you 10-15 psi more across the board.
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
