RB
Check and see which lower mounting hole your shock is mounted in. If it is mounted in the upper hole, you can gain an 1"+ by moving to the lower hole. That will lower your ride height, but you can compesate for that by raising the coilover spring adjustment. I had the same problem and this procedure cured it. Good luck.
Brad W.
A good friend will come and bail you out of jail...but, a true friend will be sitting next to you saying, "Damn...that was fun!"
