All,
Thanks for the input!
Fred - I raised it on the lift and I cannot find the markings on the rear for crap. I will pull a wheel get a closer look later.
Brad - I do have set of lower holes that I could go to, but I am not sure the coil over end won't hit the bracket. Again when I pull the wheel to find the coil markings I will relocate one to see if it is feasible to go to lower hole. Mine has spacers that have the mount all the way to one side (front side) and I know it could hit there (but an easy relocate in spacers will fix that direction), but I am not sure it won't hit the bracket on the tire side no matter where it is located in the spacers. Did you have to due any extra fabrication? BTW - love your signature line! Been there done that!
May be a combination of spring and relocate. I will tinker with some more tomorrow night. You have all given me a direction to go.
Thanks again and I will keep you posted.
Bruce
