Old 02-22-2006, 10:03 AM
grumpy grumpy is offline
Cobra Make, Engine: Self Built, 427 USRRC, 427FE, Toploader
Default what makes you feel comfortable
Jon,
Sorry the NAPA number is TS-4433721 on the previous item request, the one
I noted is a NAPA/photo number for stocking/shelving purposes I will stick with the 0.998" bore slave with a 0.870" bore clutch master cylinder, and a simple 1/4" plate steel bracket over any other combinations, and there are hundreds of methods and fasteners available.
Pressure = (Leg force on the pedal) x (Pedal Ratio) divided by (Master Cylinder Piston Area) with Pi times (radius of the piston squared) times (the piston)
Used for decades on FE/Lima big block AC/COBRA type Reproductions with out a flaw. So ever what rattles your cage.
grumpy
