LED are from Custom Dynamics
Running light & Brake light are part 3208-18 (1.85" Diameter Replacement Cluster RED)
http://www.customdynamics.com/motorcycle_led_bulbs.htm
Turn Signal & Brake light are part #3209-38 (1.85" Dynamic Cluster LED Turn Signals)
http://www.customdynamics.com/motorc...c_clusters.htm
These have pigtail for turn signel and hard wire for brake. If you look at my pic's you will notice I cut off the pigtail and hard wired them.
(pigtail is the end that fit's into a normal bulb socket)
Relay, (just about any 12v relay will do) I used this
http://www.radioshack.com/product/in...entPage=search
RS part #275-241
Also, when using LED's of this sort, you generally need to add a load, otherwise the turn signals will flash quickley (just like they do when one bulb is blown). I did not need to do this on my BDR. But you may need to, depending on what kind of flasher relay BDR used of other cars.
If you do, then this is what you would need from Custom Dynamics #4810 @ $15.25. I have one, because I fully expected to need it. so I know it fit's and works, but I did not need to install it.
Shaun
