  #83 (permalink)
Old 02-27-2006, 06:17 PM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
Kevin
The first (1958) 332 and 352 engines were solid lifter with a midyear change to Hydraulics(identified with a orange mark on the valve cover) Later high performance only type engines were solid only without the galleys being drilled. I have made oil manifold logs in the galley area with a steel line going to each lifter boss so hyd could be used--I think most of the cam failures are in non oil galley lifter bores, with no oil getting around the tappet and running down on the cam.
Jerry
