Hey, i just signed on tonight. I build aluminum cars. You always ground to the steel frame. I work at McCluskey LTD in Torrance, Ca. I will ask my partner which harness he thinks is best. He's the wizard with wiring. If you can, always solder your connections but, you should always check for continuity between ends with a tester. A good ground stud could be a machined screw welded to the frame near guages or accessories. good luck!
