Old 02-28-2006, 04:40 PM
byron w byron w is offline
Cobra Make, Engine: shellvalley 428 ford
Hi Brent,
Not sure which supports are in you frame but the mounts with the stud out the bottom are: c5az 6038 c (rh) and c5az 6038 D (lh). Or perfect circle:220-1096 (rh) and 220-1797 (lh). Or you can use the fairlane mounts which are: c70z 6038 c (rh) and c70z 6038 d (lh). Now depending on how your frame is set up you might have to use the left on the right and the right on the left. My S/V frame uses a crossmember and thats why mine are installed the latter way. It works just fine. Oh, they are 3 bolt to the block. Any questions just let me know.
Byron
