Jag Outboard brakes
Hi Bob,
While I’m a loooong way from installing the outboard brake unit, I did check, and the 12” rotor assembly does fit in my 15” Compomotive wheels. The brakes use a 48mm single piston (sliding caliper); will I have to change my rear master cylinder, and if so, to what size?
THANKS,
Dan
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
