Old 03-01-2006, 11:27 AM
strictlypersonl strictlypersonl is online now
Originally Posted by Carnut427
Hi Bob,
While I’m a loooong way from installing the outboard brake unit, I did check, and the 12” rotor assembly does fit in my 15” Compomotive wheels. The brakes use a 48mm single piston (sliding caliper); will I have to change my rear master cylinder, and if so, to what size?
THANKS,
Dan
No change necessary. Once the pads are bedded in, test the balance and adjust the balance bar shims. So far, we've never had to change anything.
