Old 03-03-2006, 05:08 AM
BUCKEYE COBRA's Avatar
BUCKEYE COBRA BUCKEYE COBRA is offline
Cobra Make, Engine: Backdraft #20 302 T5
Can someone veriy that the H2O pump is:
Reverse rotation for a serpentine setup
Standard if using pulleys
Should there be any fit problems with any of these? I just installed a standard on mine as I am running pulleys (alt,H2o) and seem to have a fit problem as coolant is running right out from behind the pump. I will be removing Saturday to see what is causing this. I would think all pumps should interchange. Mine motor is a 5.0 87.
Thanks,
John
