Old 03-04-2006, 06:01 AM
grumpy grumpy is offline
Cobra Make, Engine: Self Built, 427 USRRC, 427FE, Toploader
John S.,
The MII arms inside mounting points do not weld in the same location that the AC/MKIII chassis points, MICK and others have been thru the geometry layout phase and know this. If you welded them as the frame plans that are out there are dimensioned, will have a different track, unless you use a very different upper arm to compensate for the new lower arm geometry.
grumpy
