Originally Posted by Excaliber
I got squirt holes in the top of my rods and still run 80 psi.
The hole on the little end is for
oil splash to lubricate the piston pin.
While I've seen rod bearings with "V" notches in the indicated location, the pistons & cylinders also get splash from
oil running out from between the rods as the shaft rotates. The larger the gap between the rods (usually .025 max) the more splash.
