  #21 (permalink)
Old 03-06-2006, 12:45 PM
Carnut427 Carnut427 is offline
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
Originally Posted by BigAl
...If this makes you feel any better check out Chevrolet's minimum oil pressure specs. for new truck.
1000 RPM-6PSI min.
2000 RPM-18PSI min.
4000 RPM-24PSI min.
Don't compare bearing clearances or oil pressure needs between the FE and other engines...the FE, with it's large connectiong rod bearings, requires special attention.
MaSnaka, a look under the intake to check for an internal oil leak might be wise. You can spin the oil pump shaft (I use a bare distributor shaft) once the intake is removed. If you do decide to "just run it", I personally wouldn't do much spirited driving; you're likely to end up with a pile of rubble. As mentioned before, all any of us can do is give advice based on our own experiences; the final call is yours.
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
