Thread: Pucker Factor
  #28 (permalink)
Old 03-08-2006, 04:45 PM
Terry Brown's Avatar
Terry Brown Terry Brown is offline
Cobra Make, Engine: Superformance, #930, 351W/427CID 419 RWHP (before the Webers!)
I ran vaccuum lines on the underside of the manifold to each port. That system takes care of the PCV valve. I am running an electric vaccuum pump from Stainless Steel Brakes Corp (available from Summit or Martel Bros for cheaper).
This is a photo (perspective is off) of Traindriver's set up. Mine is fairly close.
I'm not an expert on cams, but I'm running the original Comp Cam xe262hr-12 for the 2000 FMS 392 engine. Engine is now stroked to 427 and seems to run fine with the webbers.
Good luck!
Terry Brown SPF #930 427W 419 RWHP 48 IDA Webers
"Remember, your car will not be more valuable after Track Day than it is the day before the event" - Eric W. instructional presentation on Track Day safety, 05/15/2008 WSCB
