Old 03-16-2006, 12:12 AM
stephen low's Avatar
stephen low stephen low is offline
Les
went out and took two photos, handbrake #1 and #2, don't yet know how to post directly, as pics worth 2000 words.
Pic 2 shows whole of layout pic 1 the tight bend if I have to feed cable to left of pic. to then be able to mate into both jag handbrake caliper arms LH caliper out of car at present.
My only thought, and yet to try, was to travel directly backwards through rear sheetmetal wall and bend hbrake cable in a tight anticlockwise loop, then feed into calipers.
Cable cover is quite stiff, GForce build manual is in B&W ie useless hence running out of ideas. Handbrake was supplied by GF per last owner's purchase so a GF photo should be able to show what was intended.
Are you able to shed any light?
slowy
