  #23 (permalink)
Old 03-17-2006, 05:18 AM
Andrew429's Avatar
Andrew429 Andrew429 is offline
Cobra Make, Engine: G-Force MkII, Ford 429, Tremec TKO, Jag Suspension, Sequential LPG Injection, On The Road.
Hi Stephen,
I'll get you a length tommorrow.
Mine will vary slightly from the norm, due to me ending up with two female caliper arms. I welded a a bolt into the clevis to allow this to bolt up, which doubles as a second adjustment point for cable tension. This is the end of the cable that I shortened (cut and crimped).
I drilled out the standard gemini fixture and fitted a bolt with spacer and 90 degree hole to fit up the standard jag threaded end of the cable. This sounds similar to the approach Les used.
Andrew
