Goober,
I assume because my Faria tach is "inline" and it's needed for the car to run when the ignition switch is in the "on" position, I'll have to use a jumper wire to make the connection so the car will run in the absence of the tach which is now wired in circuit behind the 8920 which is fed out of the MSD 6AL I have..correct?
