Old 03-18-2006, 07:24 PM
blykins blykins is offline
You can do it if you have a bearing press. A 9" is the easiest to work on....no having to drain the rearend grease or pull the c-clips.
You'll need to remove the brake calipers and rotors....then unbolt the axle flange from the axle housing. You a slide hammer or something similar to pull the axle out of the housing. The bearing will be pressed on the axle. Just press it off and press a new one on....then reverse install.
If you have a press, this is an easy job.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
