I did look for a manual, but no luck. I was told that I had to remove the leaf springs in order to get to the differential housing, where the inner bearing are located. This is the same place that didn't have the manuals for sale.
Is this approach true, or do the inner and outer brearings slide out with the axle, once the wheel and caliper are removed?
BTW, what is "axle runout" and how do I check it?
