Old 03-19-2006, 08:04 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
Well- I would assume that if you have bad bearings--either they are old and the seals will be bad also or the shortening job wasn't too good or----
Clean up the bearing pocket with some thing and the bearing will probably slide right in
Honestly, I would be concerned with WHY your bearings are bad, wheel bearings, if installed properly will go well over 100,000 miles
Jerry
