Old 03-23-2006, 12:55 AM
littlebluecj-5 littlebluecj-5 is offline
Default 427 sideoiler (C5AE-H)
ok im reposting this sorry because i couldnt find my original post i would also like some imput on the pricing thanks
427 sideoiler (C5AE-H)has been properly stored for about 30 years less then 10k on motor
427 std.bore short block assembly
427 std.forged steel crank (C5AZ-6303-C)
7000 RPM cap screw rods
12.5 O.E.M fomoco pistons
crane flat tappet solid cam 310x533"
fomoco (C4AE-6250-B) 324X500"
fomoco (C8AX-6250-D) 330X600"
crane hollow shell lifters new
crane pushrods new
427 high riser heads (C4AE-6049-F)
extra set exh valves new (C5AZ-6505-N)
8v high riser intake (C4AE-9425-F)
4v high riser intake (c4ae-9425-g)
8v med riser intake (C5AZ-9424-G)
8V tunnel wedge intake (C8AX-9425-A)
matched set 600 holleys
715 cfm holley
(2) fuel logs
(2) dual quad oem linkage
dual quad cast alum air cleaner (C5MY-9600-B)
high riser adj rocker assmbley (1) set
fomoco hardended washer head bolts (new)
fomoco chrome valve covers (fair condition)
m/t cast alum valve covers
fomoco dual point dist. (C5AF-12127)
mallory w/tach drive dual point dist.
fomoco 11.5 hi-perf flywheel and zoom clutch assy
fly wheel assembly (C5AZ-6375-P)
fomoco hi volume oil pump (new)
fomoco reverse sump oil pan and pickup tube
r.c 2 part blowproof alum bellhousing as used
on 427 thunder bolts
toploader 4-speed wide ratio
toploader 4-speed close ratio
hurst comp plus t-handle shifter w/rev lock out
misc top loader new gears (not sure of ratio's)
*extra 1964 427 highriser forged steel crank
needs to be cleaned up/surface rust on journals and
slight pitting
less then 10k on motor no rust in water jackets
all machined sufaces not damaged no ridge in cylinders
no bolt holes stripped or threads pulled out
everything is like it came from the factory everything
is standard size bore,crank,rods etc
all parts rust free unless * notted
this engine was bought by my uncle brand new from
fomoco
$14,000obo located in michigan
my uncle told me that the one toploader trans was built by the guy who use to build dyno don nicholsons transmissons he has the original blueprint sheet from when it was built it has very low miles
