You may want to check if the sensor is VDO as well.  A generic sensor or other brand will NOT work properly.  I had both
oil pressure and
oil temp VDO gauges not working properly on the GT40.  When I called the factory, they said I have to use VDO sensors.  I got them from Jegs or Summit, replaced the sensors, viola! works like a charm.
