Slowy,
You're correct re 2004. Vicroads gave a concession for builds starting b4 1/1/05 only needing to comply with ADR 37. Clincher is only 3 years to build. (eg if you start the build in 2004, you have until 2007 to finish) Late model ford wuld be your best option. Early Ford V8's will only have 165kw. Probably best to go late model Tickford. I was lucky enough to find a T3 5.6ltr, you might be too.
