03-28-2006, 03:17 AM
QLD
Cobra Make, Engine: Drb,5.6 8tb Windsor,TFS heads,Dart Shp,TKO600 ,4link 9in diff.Ford acid rush Paint,convopro wheels.
Hi Steve,
I actually posted on your original thread so will have another go!
Its good to know you can use post 97 engines ,
and if you specifically want to fit a windsor I would search for the last of the Au3 engines ,I think they were 225 kw.
The tickford T3 strokers were 250kw but I would think these would be almost impossible to get and probably too expensive.
Things to check for...
70mm Mass air
65 mm throttlebody
24lb injectors (blue) Not orange 19lb
Cobra Intake upper and lower(staggered circular ports not oval inline)
These engines are basically the same as an american 86-93 Ho engines anyway and dont really use any of the 94-95 engine specific parts.
They do however use australian specific ECUs with smartlock etc which will need to be re connected..
Peter..
