  #183 (permalink)
Old 03-28-2006, 04:05 AM
Ron61's Avatar
Ron61 Ron61 is offline
Question
Tru,
Isn't the reason for an underdrive setup to save a few horsepower and spin the pulleys faster or do I have that in reverse? As for the voltage, could you go to a smaller pulley without having to do everything over? I just have the standard size pulleys on mine so I don't have any voltage problems. It runs around 13 1/2 to just a hair over 14 volts. If I am correct about the underdrive spinning tha pulleys faster, then the water pump would be pumpng the cold wather through the engine faster and it will take a little longer to get heat in it. But it sounds as if you are making a lot of progress.
I did get out yesterday morning and mowed the high weeds in the yards and it was so wet it was miserable. Three hours later it was raining again.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
