I used three switches. The first is an ON-ON for high and low beams. I have a regular headlight switch on the left side of the steering column. The second is a spare for later. Right now I use it to turn the fan on if I want it to run and the fan temp switch is not closed. I may use it for something else later if I need it. And, the third is for the wiper. It is a ON-OFF-ON switch. I did not worry about a “park” position capable switch for the wipers. Who uses them anyway?
