If your clutch needs ajustment make sure master cyclinder is full first, bleed if need be. Make sure ajustment on clutch peddel in car is set and tight and lock nut is set they can come lose.The clutch rod on slave cyclinder has ajustment thread to set engagement, make sure the boot on rod is in good shape!!! or cyclinder will not last long ,do to dirt.
If it is just using a threaded rod. weld a washer on it to hold boot in place or the boot will tear.
Good luck ED
Ed
