Originally Posted by Barry_R
Fun to listen/read about FEs needing special treatment and tons of oil pressure. Sadly its just not true. FEs have their quirks, but they behave and react exactly like every other engine. And they dont need very high oil pressure to live...
Some clarification is needed on this issue. We’re comparing apples, oranges and grapes.
The “top oilers” all Fes except 427 side oilers with standard FE-sized rod bearings of 2.438”,
“Top oilers” using cranks with BB Chevy-sized rod bearings of 2.200” and a bit wider than the FE bearing.
427+ side oilers with BB Chevy-sized rod bearings of 2.200” and a bit wider than the FE bearing.
I’ll give in to your
oil pressure requirements on side-oiler blocks when using cranks with BB Chevy rod bearings. However, the others are a different animal, and IMO especially the top oilers.
Most machine shops, where a lot of engines are built, build more Chevies than anything else, so they know what clearances work on them. Along comes a top-oiler FE, which oils the cam first, then the mains, and finally the rods get their oil from the oil pressure surrounding the main bearing. Add to this their larger diameter rod bearing. Using the rule of thumb of .001 clearance per inch of diameter, the standard FE naturally needs more clearance than the Chevies most shops are used to. Also, with a larger bearing size comes more surface feet per minute, meaning there is more friction on any given spot on the rod bearing because of the larger diameter of the rod throw. If you’re building a stock or mild top-oiler, everything will be fine. However, modify your heads, put on a good intake and add a cam so that you’re pushing 6000 rpm or more with it’s higher hp, and you’d better make some changes to the stock oiling system if you want the motor to live. If Ford thought it wise to increase the oil pressure to over 100 psi on the side oilers, doesn’t it make sense to make the same modification to a high performance top oiler? I certainly think so, and IMO high volume pumps are a given in anything except your standard grocery getter. They’re cheap insurance.
Obviously, everyone isn’t going to agree with me, and there’s nothing wrong with that. The better oils available today help considerably, especially the
synthetic and diesel oils that still contain
zinc.
Dan
