Do your brakes feel "spongy?"
Do any of you have a "spongy" feel with your brakes when you depress the pedal? This car is #299 still fairly new with 600 miles. I believe it has been this way from the start. There are no visible leaks from the wheel cylinders and the car dose stop but I just have that feeling like I have volkswagen bug brakes and they could go at anytime. I'm wondering if one of these heat shields would make a difference maybe it's the heat. Once in while The master cylinder will drip like one drop on the headers but it's not leaking it's just not completely dry around the entire thing. Should I try to bleed the entire system-what do you think?
Thanks for your time
Mike
