Thread: wiring mess
Old 04-02-2006, 08:52 AM
strictlypersonl strictlypersonl is offline
Originally Posted by olblue66
Well i tried to wire in a pushbutton momentary switch and a regular switch to cut all power to the acc. side of the key switch. Did away with key switch. Any one else do this. If so , can you explain how you did it. Im at wit ends on this mess. Thanks
Please explain exactly what you want.
Do you want a single master switch for all power, and a pushbutton starter switch?
Do you want the starter switch to function whether the master switch is on or not?
Do you want the ignition circuit separate from the other accessories?
