Well I have the pushbutton on seperate power and its ok. Now I would like to kill the power to anything after the switch---all acc. and the ignition. I also have a msd ignition, not sure but i think it picks power up from somewhere else. The power was going to the the battery terminal on the ignition switch. Then acc. on one side,and ign. on the third side . The center was for the starter.
I would like to kill all voltage after the toggle switch is tured off, including ignition. I think there 25 to 27amps with all loads on. Checked them in line with a meter.the meter only goes to 10 amp dc.I checked them seperate, one at a time. Could i put a 40 amp dc relay in line so the switch would be ok.
thanks
