Old 04-02-2006, 12:00 PM
frankym frankym is offline
Cobra Make, Engine: ERA 575 with Shelby Aluminum 427 Stroked to 468
Default superformance bad fuel pump questions
I think I've diagnosed my problem, the carb isn't getting any fuel. It ran for a few minutes and then I thought it was flooded but after trial and error, it would only run if I was dripping fuel into the carburetor. I then noticed that when I turned the ignition key, I didn't hear the hum of the fuel pump that can usually be heard when you turn the ignition. I need help in determining that I have the right diagnosis, and then I need help finding the pump? is it by the tank and what needs to come off before I can spot it and remove it to replace it. Thanks!
Frankym
