Old 04-02-2006, 01:59 PM
rob frink rob frink is offline
Frank, Not sure if yours is like mine...but on my #1429, I use an electric fuel pump which is mounted just inside the main frame rail next to the rear-end/ differential housing. Mine is rigidly bolted to the frame and I can hear it run until I fire the motor. It is very accessable. Just pinch of the fuel lines, un plug it and remove it.
Not sure if this is your first time running the car...? Maybe the fuel pump switch is turned off. It is located on the dash in between the speedo and tach. Down is "on" and "up" is off on my car. I'm not being sarcastic...I just don't know if you know...sorry.
Good luck with it!
