Old 04-02-2006, 03:35 PM
CobERA's Avatar
CobERA CobERA is offline
Cobra Make, Engine: ERA #644 428 FE
I installed an oval air cleaner on my ERA. I also have a 428. It takes a little work, but it is not hard.
First you must cut out a portion of the underside lip on the hood. There is a diagram in the ERA manual. I was skeptical about cutting the hood, but it wasn't hard.
I also bought a blank steel bottom plate from Tony Branda. The usual aluminum bottom plate was just a little too thick, and caused the top to rub on the hood.
The blank steel plate is very thin. I cut out the opening to fit on top of the carb and two holes to allow the float bowl adjusting screws to protrude through the base.
I also fashioned my own hold down bracket using strap iron and some bolts.
If you are interested I'll take some pictures and post them.
Rick
ERA 644
I'm getting old too fast and smart too slow!
