Old 04-02-2006, 05:40 PM
Bob In Ct's Avatar
Bob In Ct Bob In Ct is offline
Cobra Make, Engine: SPF - 351W, 944 non-turbo
Doug:
Be sure to strike the spinner in the correct direction. I rotate the wheel 120 degrees after each strike. Use a lead hammer.
Don:
No offense taken. Keep in mind that much of the safety wire used on our cars is very thin and may not hold like the aircraft stuff does. Regardless of whether you leave it slack or tight it should be checks very often.
Bob
