Old 04-04-2006, 06:53 AM
d_ford's Avatar
d_ford d_ford is offline
Cobra Make, Engine: CSX4000, Shelby aluminum 496 ci FE
Default 427 stroked with 428 crank balance question
I have a Dove aluminum 427 tunnel port that was stroked with a 428 crank and rods. It has an aluminum flywheel that I want to replace with a light weight steel unit since I'm putting it in a heavier car (mustang). My question has to do with the balance. Can I reasonably assume that it was internally balanced and therefore would use a zero balance flywheel? I didn't build the engine initially and I know there are balance differences between the 427 and 428CJ engines. The aluminum flywheel that came on the engine doesn't have counterweights cast into it but it has been drilled a number of times. (probably for different balance engines?) I don't want to have to take this thing to a shop just to find out how it's balanced just so I can buy a new flywheel for it. As far as i can determine, it was originally built by a shop called S&S engines possibly in Iowa. Any input greatly appreciated.
Doug
CSX4761
ERA #115 - sold
ERA #002 - sold
07 GT500
66 GT350 tribute
70 Mach 1
65 Comet gasser
