Old 04-04-2006, 09:30 AM
Jeff Frigo's Avatar
Jeff Frigo Jeff Frigo is offline
Cobra Make, Engine: ERA 454 S.O.
Originally Posted by tpiini
If you have holes drilled in your current flywheel, you're definitely not neutral balanced.
Don't be so sure of that statement. Depending on how many, and how big the holes are, this could be to done to get a zero ballance.
I use to work for GM in the flywheel dept. almost every wheel had hole drilled in them.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
